zpd307
am i going to have to seperate the up pipe to get it in? i gave everything that i can remove out of the way, but i still cant get it up and fit from the bottom. any tips.......
that's how I do mime. unbolt the cab and lift. only additional thing I do is unbolt the steering column and brake master cylinder.Unbolt the core support from the frame mounts and unbolt the fan shroud. The pull the carpet back and take out the 2 front cab bolts. If still an automatic then disconnect the linkage at the trans. Now jack up the cab and put 2x4 blocks between cab mounts until desired clearance is achieved
