Correct way to install injector line clamps on 7.3
Exhumis
Virginia
94 7.3l. When I bought it the PO had installed new pump and injectors at some point but didn't put the clamps back on the lines cuz reasons. What's the proper way to put them back on? I looked in my shop manual but didn't find the answer. I'm assuming crack the lines at the injectors so there's some give, install the clamps and then tighten the lines back down?
onetonjohn
California
Clamps on the return lines? If so, I would probably pull the lines and pop the caps off with them all connected and then do it on the bench. Others might do it on the car - more than one way to skin a cat. You could try it on the truck and if it doesn't go smoothly, then pull injector lines and the the caps.
chillman88
Central NY
I think he's talking about the rubber lined anti vibration clamps.
I just put mine on, my lines were close enough that with a small amount of finagling they fit decent. I didn't bother loosening them or anything.
Exhumis
Virginia
No, clamps on the metal injector lines, not the return lines.
Exhumis
Virginia
Yeah those. Mine are not close together, I think they've been run for awhile and have vibrated enough that they are no longer side by side but separated by about 4mm or so and are not on the same plane.
Use a small flat head to separate them into each channel in the rubber clamp, and use a small C clamp or vice grip to clamp it together while you put the bolt and nut on, if you try to use the bolt to tighten it together you’re gonna have a hard time.
Exhumis
Virginia
Ah ok cool, thanks for the info. So I don't need to loosen the lines up? Afraid of damaging the fitting.
Nope, just be gentle and youll be fine. You want it to clamp the lines in the position its in on the injectors, otherwise its easy to get cross threaded.
Exhumis
Virginia
There is also a prescribed way to attach them, a guide as to where they go.
Awesome thanks for the diagram. PO had sanded down the lines so there were no clamp marks and I was going off of Google images.
Selahdoor
Index Wa
Now you tell me! BAHAHAHA LOL
mblaney
Ottawa/Ont/Canada
Do yourself a huge favor and weld the nut to one of the clamp halves. Then you don't need frigging triple jointed fingers, a magnetic pick up tool, too many beers and a hangover to put them back on.:cheers:
IDIBronco86
