Zf5 swap on an 87, what year pedals?
91crew
San Luis Obispo, CA
I'm going to put a zf5 into my 87 with a c6. What year trucks can i pull the manual pedal assembly off of? Is my list of stuff correct:
Transmission
Flywheel,clutch, pressure plate
clutch master cyl. and lines
pedals
tranny tunnel
91crew
San Luis Obispo, CA
Thanks Towcat. Also, will i be able to keep using my gear vendors since it bolts up after the transfer case?
dieselutheran2
Berkeley
I found the zf5 is only about .5 inches longer than the C6. I was able to re-use my drive shafts. The master cylinder hunt is a great game. Like EMD Driver, all I could find was one that had offset mounting bolts. I made a pattern of the master cylinder mating surface and drew it on the firewall before drilling, that way I could clock the MC so it will be straight up and down, rather than turned 20+ degrees left.
Don't forget the pilot bearing for your flywheel. I also took the opportunity to have the machine shop flip the flywheel ring gear so I have brand new fresh teeth for my starter to engage with.
