C
cash
Guest
I know the answer would be told if I had the means to set the dynamic timing but I don’t and won’t for a while so I want to do the best I can with what I have. Bet most of you have been there.
Here it is, I rebuilt this 7.3 idi na and have sense put 2000 or so miles on it I took the injectors in to this local shop they pop tested cleaned and set 6 of them at 1500psi
the other two they replaced with new Delphi. Said Delphi on the package and made in Mexico on the injector.There coed BBAnyhow the thing smokes bad, runs rough and white smoke at cold start. Once it gets up to running temp it clears up. Runs ok. It never smoked like that before.
I think some may say you got air in the return lines, so I’ll tell you now. In the morning the filter is full and I have had a clear plastic line on the return from the filter and never seen any air. Still think its air? Tell me and I can put a Holly Blue on for a while.
Back to the story. Then I changed the injectors put in a set of Bosch used from a 6.9, still smokes at cold start.
So I advanced the timing more as far as the bolt slots would allow and the thing has more power than it ever had and no smoke, not even black, once it warms up. It is quieter with these Bosch injectors also. I will have to wait till morning to see what it does on a cold start now.
I thought if I had the timing close that.
1. It should blow some black under load.
2. Rattle pretty good
3. Not over heat
Note: static timing mark is off less than 1/8”but remember it is as far advanced as the bolt slots will allow (this pump did not come on this motor so static timing marks don’t mean much, I guess?)
Compression tested good.
Would a week IP make white smoke on cold start?
What do you think of setting the injectors at 1500 psi?
Should I try another IP or maybe drill out the bolt slots on this one to advance it more? I think it needs advanced a little more.
