Would this be at all useful for a filter head? How does it hook up?
ghunt
Morgantown, WV
I got this filter head for dirt cheap awhile back thinking I could possibly use it (well, it was two heads together on a bracket). They're off an old International dozer with a DT807 (I believe) in it.
The two filter heads were identical, one had a Fram P1125 on it and the other was a P1118. I was only able to salvage the one head because the filter was rusted on the other one. They're both the same filter head, kind of an odd setup as it has a long tube that runs down the middle of the filter. They're big filters too, about 8" long.
Anyway I was looking at this head tonight and wondering how they hook up. As I got it, shown in this picture:
Starting at the front, since I need to explain the top one last...
Front fitting was connected to the top fitting of the other filter head by a hardline.
The fitting on the left side had a short piece of cloth braided tubing (with crimped on metal fittings) threaded on to it. I guess this would be the outlet? There's an identical port on the right side of the filter head, it had a plug in it.
The small plug on top of this one was just, well...a plug, but the other filter head had a brass bleeder screw in this spot.
Finally the top fitting I believe didn't have anything attached, not sure where it goes. Also I removed the top fitting and it looks like this:
What is the function of that?
Anyway I don't know what I would use this for...apparently the filters it takes are rated at 12 microns... :dunno
87crewdually
Southern Nj.
Fram P1118 = Napa 3341: primary 30 micron
Fram P1125 = Napa 3342: secondary 10 micron
The fitting with the tube I'm assuming was in the primary (first) filter and lead any fuel/water straight to the bottom of the filter. Just a theory.
MIDNIGHT RIDER
Like many universal filter-heads, that one has options for various inlets and outlets, which is what the plugged holes are.
Most also have a 1/8-NPT port in the top for either/or bleeding and attaching a gauge-line.
You don't necessarily have to use that head paired with another.
You could run a PRIMARY filter on that head and let the factory filter be the secondary.
Most of those heads are of a standard thread and surface area, thus allowing a whole host of various filters to be used.
Filter diameter is not too critical, so long as the O-ring-seal compresses on the machined surface.
That head looks like it would clean up and work. ;Sweet
ghunt
Morgantown, WV
Hm...weird...I looked up the baldwin intercharge numbers which come up as BF978 and BF979...and some website I found said they were both 12 micron?
Wondered why they would both be the same, I guess that isn't quite right.
Thanks for that info though, I might try the 30 micron as a pre-pump filter or something. So basically any filter that will thread on and is long enough to clear the center post on this head will work? Looks like you can get some neat filters for this head...I've found some clear down to 2 microns, and a 140 micron wire mesh version. Cool :)
So which port should I use for the inlet...the one on the front, or the one on the top?
87crewdually
Southern Nj.
BALDWIN
BF978.................... 3342
BF979.................... 3341
SPECS & CROSS REFERENCE
3341
Element Dimensions
Height O.D. I.D. THREAD
7.827 3.698 1"-14
Gasket Dimensions
Number O.D. I.D. Thickness
Attached 2.834 2.462 0.255
Principal Application
IHC, Agco, Dresser, Galion, Case, Fiat-Allis,
Komatsu
(Primary) (30 Micron)
Interchanges
AC DELCO.........................TP972
ALLIANCE ...... ABPN10GFF5020
ALLIS-CHALMERS...... 40394407
BALDWIN...........................BF577
BF979
BIG A FILTER.................... 95341
CARQUEST ....................... 86341
CASE..............................A184773
CATERPILLAR ................. 3I1331
CHAMP (ALSO SEE
LUBER-FINER)..............FP251F
CHAMPION
AUTOMOTIVE..................HF514
COOPERS........................AZF037
DELUXE........................... WD352
DONALDSON ............FFP170627
FFP555627
FFP558050
P555627
FIAAM ..............................FT4937
FLEETGUARD.................FF5020
FF5020J
FLEETRITE................... FFR8184
FFR85020
FRAM.................................P1112
P1118
GALION............................D99501
GENERAL MOTORS..... 6438704
GLOBAL FILTERS ............ 40979
GONHER......................... GP1108
GP1108F
GP3692F
HASTINGS............................. 985
FF985
HEAVY DUTY AIR ......HDA16013
IHC ...............................625627C1
625627C91
702251C1
703420C91
KOMATSU ............... 3816256271
KRALINATOR...................... F170
LUBER-FINER (ALSO SEE
CHAMP) .........................FP251F
MAHLE................................ KC13
MIGHTY..............................FS132
MOTORCRAFT....................FD61
PROMATCH.....................9Y4429
PURE FLO .....................PFF1108
PUROLATOR................... F60132
PER132
TECNOCAR...................... RN117
TEXACO............................HDF14
THERMO-KING................ 125704
125704A
WHITE........................ 303073157
400002512
WIX..................................... 33341
WIX OLD NUMBER ......... 533341
WOODGATE..................WGF184
WGF5017
WGF5020
MIDNIGHT RIDER
So long as you choose the proper directions of flow, it matters not which ports you use for the inlet or outlet.
Use whichever ones best suit your location/position.
If they are not marked "INLET" and "OUTLET", then poke a wire down each one and see where the wire enters the filter area.
The center hole of the filter cartridge is the outlet. ;Sweet
ghunt
Morgantown, WV
The CENTER is the outlet? Ahhh...good to know, haha! I thought it was the other way around!
So I got to messing with the other filter head tonight and I managed to get the rusted remnants of that filter off as well...so now I have two nice filter heads I can use ;Sweet Glad I didn't buy an aftermarket one!
Now I can start working on setting up my electric fuel pump.
Most OTR diesel trucks and busses all have a dual filter system "Primary and Secondary" filters. Like said there are all kinds of micron filters available. If you are using an electric pump, the filters go after the pump, Electric's PUSH, Gear or Diaphram pumps PULL.
