Would this be a suitable filter?
EMD_DRIVER
Say what?!?!
Beaufort, SC
I am considering deleting the fuel bowl in my 99 and already have a filter head for the following filter. Would it be suitable for a post-pump filter for the 7.3? It is the same micron rating, as the stock filter.
EMD_DRIVER
Say what?!?!
Beaufort, SC
I pulled up the specs and found this...
Weight: 1.0 lbs
Notes: With attached cap
Air/Fuel Intake Height (In): 5.5
Air/Fuel Intake Length (In): 5.3
Air/Fuel Intake Width (In): 5.2
Filter Material: Plastic, Metal, Engineered Media
Performance Item: OEM Standard Part
Package Contents: Filter
Smallest Particle Filtered (Microns): 10
The Racor filter for the 99 7.3 says it's a 7 micron..
What I'm looking for, is a filter that will fit the base I already have. The threads are 1-12 and the gasket dimensions are listed in the original post...
EMD_DRIVER
Say what?!?!
Beaufort, SC
what did this filter head come off of?part number?
The head is made by GPI and it's their part number 3950301..
I'm making a mount for it and want to mount it just after the pump and on the frame..
EMD_DRIVER
Say what?!?!
Beaufort, SC
Oops... Maybe I have a different one then.. The one I have is for putting on a transfer tank, like on a farmer's fuel tank. I can get filters ridiculously cheap, since they are the same fuel filters, we use in our locomotives at work. That's the biggest reason I wanted to try using this filter head. The filters we use at work, are the Baldwin BF971..
94f450sd
somewhere,ma
im running a SD electric pump with a 5 micron pre pump and 2 micron after the pump.
EMD_DRIVER
Say what?!?!
Beaufort, SC
Who is Nick? I haven't had any problems, stock pump with 196k on it (filter has not been on the whole time but I would guess at least the last 80k or so).
Nick is Double-S-Diesel..
If it works for you, I may just give it a try.... Why not??
