Kevin 007
Full-floater
I have a 99 SD with a bad engine. And an excellent runner in a 1995 E350 that I want to swap in. Just to clarify what all I need to change over. Running the SD ECM.
-Injectors and harnesses from the SD swapped onto the 1995 engine.
-Turbo, plenums.
-Mechanical fuel pump delete, for the electric pump in the SD
-HPOP from the SD.
-Accessory drive.
Does the front cover need to come from the SD engine?
Anything else that i'm missing?
-Turbo, plenums.
-HPOP from the SD.
-Accessory drive.
