Had an awesome day today! Started off, by bleeding the master/slave cylinder. Having the bleed screw on the slave, made it so easy! With some help from my kids, we got it done in less than ten minutes.
Then I hooked up the neutral safety switch on the clutch:
I took the four allen-head bolts out of the shifting tower and put two gallons of ATF in through the hole. After that, I put the floor pan back in and put the carpet back down. I cut the hole for the shifter tower.
When I put the 4wd shifter in, it looked like it belonged there.. Even though it sits a lot higher than it used to. Once done in there, I went back under the truck and put a ziplock bag over the solenoid pack connector. I used zip ties to hold everything together and out of the way. It now sits happily over the transfer case. I also refilled the transfer case with ATF, since I lost a bunch of it during the swap.
Here's another pic, better showing the orientation of the wiring harness.
The next two pics show the shifters in place. I broke the 4wd boot, when I was trying to remove it. The screws were so packed with junk, that I couldn't get them out. I also didn't have everything I need, to mount the main shifter boot to the floor. It's just sitting there for now.
I put the lower trim piece back in under the steering column. I'll have to re-wire the brake controller, since I used the master cylinder cover plate to run the wires originally. Since I don't yet have the proper rear drive shaft, I just locked the hubs in and ran it in 4 hi. Having it this far completed, I just HAD to take it for a test drive!!! It shifts great and feel so sweet!
