JeffMoss1
Jeff
Sorry for posting a new thread about the same thing, but i'm desperate.
I changed my fuel lines,
made pretty sure there were no leaks,
held in the schrader valve to bleed out the air then when fuel started coming out i let go,
cranked it a few more times...waiting between cranks,
still won't start...
I tried loosening each nut on the ends of the high pressure lines to bleed out the air, one by one while cranking and tightened when i saw fuel coming out. I figure i shouldn't have to loosen them much to get the air out right?
I then replaced the fuel filter and did the whole bleeding routine again.
Still can't get it to catch.
Is there anything else I can do? Please help.
~Jeff
~Jeff
