WilltheThrill
I replace the top rad hose today, I fire the old beast up,(first time in two months) and I notice the fan has some back and fourth movement. I shut things down, everything seems tight except the shaft coming from water pump. I am assuming I get to replace the water pump? I look at autozone, there are two types one warns of IP failure? I am assuming the Ip failure does not include the v bellt system on the 87.
I need to get the manual trans I want, then pull this motor and freshen things up while it out before it is transplanted in the chevy.
