Wiring dilemna
Brucekoukalaka
Camrose AB
I've recently purchased a 1991 F350 with the 7.3 IDI and a ZF5 to swap into my 1953 International 1 ton and would like to eliminate most of the wiring that I no longer need. Is there a good wiring diagram just showing the circuits I will need under the hood? My intention is to clean up the rats nest of wires that were cobbled up by a previous owner when it was used as a service truck. It has been about 10 years since I worked around a 7.3 so my memory is a bit fuzzy on these old gems. I used to work on them for Uhaul but never got into changing the complete wiring harness just patching up what was needed.
gonecrazyi
florida
All you really need is a hot to the pump, a few sensors of you want to use the stock ones and wiring to the alternator.
swervyjoe
denver, co
That's about the sum of it. I have 3 switched wires going to my engine: IP power, high idle, and timing advance. Other than that, glow plugs and whatever gauges you choose to run.
I think we all would like to see a build thread on this beast.
Brucekoukalaka
Camrose AB
I'll post the pics of what I have gotten done so far. and yes I'll be doing a full build thread on my baby.
Brucekoukalaka
Camrose AB
It's been a while since I was on this forum (mainly because I lost my hard drive) so here I have some updates on my '53/'91 'Binder...
This is what the F350 looked like when I bought it and drove it the 40 kilometers to home.
here it is after a couple of hours after I got it home
and here I have the R130 cab "thrown onto its new frame
Cab set up where it belongs
and pretty much how it is sitting now
Brucekoukalaka
Camrose AB
As soon as I get it through the out of province inspection it becomes my daily driver and I will get rid of the POS gmc 4X4 I have. BTW welcome to the Oilburners forum ArcticDingo I live north of you in Camrose.
I used to have a full set of wiring schematics here. But Webshots deleted all my albums which contained hundreds of useful pics and diagrams. :(
Danielle
No, it's not finished
Dirty Jersey
I couldn't help but notice the rust free bottom of that cab that was THROWN AWAY! You guys don't know what it's LIKE here! haha
Do you want Mitchell Diagrams? I can figure a way to post them if you want?
Brucekoukalaka
Camrose AB
Actually the floors were in very rough shape on the passenger side as well as up near the kick panels on both sides. As for diagrams, Mitchell are very good ones. Thank you.
cpdenton
Truck needs paint.
Conway AR
I guess I am glad I live down south. I have only seen 1 cab in salvage yards here with more rust than that one he cut up, and I am pretty sure that truck had been under water for a while. Even one little pin hole around here means its a rust bucket.
