will a f3500 or big tilt hood fit f350
hotshotidi
Newton nj
will a f600 or big tilt hood fit f350
I searched and searched .I know 99 and up f650 front tilt hood will fit f250 or f350.I also know anything is possible with a welder and I am fabrication.I just done know if it will look dumb I'd probably need to during the hood and i have no fiberglass experience I am appreciate any input.
I am sure if you are a qualified welder/fabricator etc, you can make it fit, it's clearly going to line up with body lines.
Making it fit/work is entirely your part though.
TWeatherford
Flagstaff, AZ
A few years ago I read about a fiberglass tilt front end for our trucks that looked just like the stock front end. Not sure if they're still made though, iirc they were around $2k.
hotshotidi
Newton nj
Holy craps 2 k I have a junk yard that has many ill measure next weekend thanks
racin460
York PA
The f-600 cab is the same as the pickup cab. all is the same with a downer f-600 you will have all the parts needed to bolt right on. Just remember the fenders are on the out side of the hood. So you will be widening your truck about 36"
tke395
