Where to plug this vacuum line in
Suleiman Saadeh
North Carolina
Though I have to admit when I bought one a year ago I didnt know anything about bleeding brakes and like an idiot I didnt read the instructions and being a young know it all at the time I ended up using the hand pump and pumping a crap ton of air into my brake system. I bled them for and I'm not exaggerating for 5 hours and still had small amounts of bubbles coming out
renjaminfrankln
Raleigh NC
Is there a possibility that this, solenoid I believe, could have got damaged in the engine fire? I got a vacuum gauge last night and I'm gonn see if my system is loosing vacuum but if not what would that thing be called?
Does anyone have a pic or can explain where this recirculation solenoid hooks into the vacuum system.
Mine is not connected to anything.
Selahdoor
Index Wa
Mine goes down into the heater fan box, along with a bundle of wires.
Best pic I have. I drew a green line alongside the vac hose. (It's a black line, that loops down, then goes back up to a white plastic line, that runs inside with the wires.)
chillman88
Central NY
There's a connector inside the passenger kick panel if you have to run a new line.
renjaminfrankln
Raleigh NC
Thanks for the help. I had to trim the conduit back but I found the vacuum line. Reconnected with new rubber connectors. All the functions work now :cheers:
If only everything else was this easy!
tke395
