Where to find drive shaft parts?
stevebates
alexandria va
93, NA, E4OD, Regular Cab, long bed, 2wd, one piece drive shaft. The front driveshaft yoke wore out. In need of a replacement. Anybody have an extra serviceable one laying around? Thanks in advance.
1mouse3
il
Local drive line shop
That is a start and cheaper if grab a shaft from the yard with ends that will work, longer is better than shorter because the latter needs a new tube.
Since its just a yoke your short, grab any with a good one and take both to a drive shaft shop.
Big Bart
Tow&Slow
Newport Beach, CA
I would also replace both u joints and the carrier bearing if you have one while it is out. Also a good time to change diff fluid if due/over due.
The local parts stores have a selection of new front driveshafts for sale. Probably the same thing you are getting off ebay. Something from a aftermarket company like Dorman.
m2rtin
