mankypro
Learning Slowly...
Ok so my lug bolts are reverse threaded? Are everyone elses?
Pretty funny when you take a torque wrench to them
The idea of lugs coming loose at high speeds? As I said, it's since been disproven...how does that happen.
The engineering wisdom behind these "backward" wheel fasteners is no doubt based in the concept that inertia on the driver side of the vehicle could hypothetically act to loosen a conventional righthand fastener as the vehicle accelerates and brakes while moving forward. A similar strategy is employed on most bicycle pedals: the lefthand pedal and crank end having lefthand threads. Here it works great to keep the pedal from unscrewing while you ride and has contributed to a worldwide shortage of choirboys. But when it comes to cars, there are dubious benefits as proven by the fact that GM, and yes even Mopar, eventually abandoned the use of these wacky fasteners.
suv7734
I bet someone has swapped the right and left hubs, the left hand threads were always on the driver side, I have owned lots of old dodges and they were this way till the early 70's
My torque wrench broke right after I switched to the driver's side on the first nut. So is the front driver's side going to be left threaded too?
