What to use instead of Mercon?
razorback
branson, mo
ok got the bottle out of my garage to make sure it wasnt type F. here is what it says:
meets mercon requirements, and do not use in mercon 5 or mercon SP.
funnyman06
Coventry, RI
So in my C6 what should i be running. I just did a complete flush and filled up with Type F. Is that what i should be using? Or did i screw myself?
Mr_Roboto
Elyria, near Cleveland Ohio
It should say on your dipstick. However either Type F or Mercon is FINE in your transmission. Mercon will give softer shifts if that is something you desire.
The problem with Mercon V is that it is chemically incompatible with older transmission internals.
suv7734
BC Canada
A quick search of the suppliers shows most are still providing Dexron III/Mercon. Some are also showing products that are compatible with both the Mercon and Mercon V spec. Quaker State shows their product compatible with both. Pennzoil also shows a product (high mileage ATF) that is Mercon compatible which would make sense since all our transmissions are considered high mileage. Castrol, Havoline, Valvoline and Chevron all show Dexron III/Mercon as available.
I think Brad Penn is making it. They are rapidly turning into my favorite refinery.
m2rtin
