i found a used hypermax turbo kit a buddies wrecking yard today
it has the down pipe, both exh manifold to turbo pipes,the cowl intake piece but no tube that goes to the turbo,he said hes got the piece that replaces the air cleaner housing hes just got to find it but no tubing to go to the turbo, no oil feed line, he has the pyro and boost gauges, what is used for a air filter, any way 300.00 bucks i thought that was a screaming deal but what should i look for as far as wear the impeller looks good and i cant feel any play in the shaft is there anything else to check for
thanks mike
thanks mike
