What others parts can swap from a gasser
Axles if is is a f250 HD. Transfer case. Driveshafts. Steering box/column. Wiper motor/blower motor. Wheels, brakes. Transmission if it was a 460 and you want to drill some holes in the bellhousing.
fyrfghter
Lebanon OR
Cab swap is possible? I want to do an extended cab to crew cab swap on my idi. Finding a blown gasser sounds easier then a diesel
Thewespaul
Bulverde, Texas
Pretty sure the frame is different between the ex cab and crew cab
fyrfghter
Lebanon OR
Most likely, I haven’t compared yet but fabrication is not a problem. It will be a while though I have some other plans first
david85
Campbell River, B.C.
Core support, engine cross member, front anti-roll bar (2wd front end) and the diesel indicator lights (WTS, water in fuel, overheat).
Those are the main components that are different between the gasser and diesel trucks. Everything else can be swapped over, provided both trucks are F250 HD. If they are light F250s, or F150s, then the running gear will be lighter duty than a diesel. Ford didn't really have to modify the trucks very back in 1983 model year when the diesel option first appeared.
BRShirk
Greenville SC
Darn, I was hoping to be able to use the core support.
With exception of the diesel specific indicator lights can and glow plug harness I use any of the wiring?
Is the issue with the core support the bolt pattern for the radiator or strength?
The diesels use a humongous radiator that will not fit in a gasser core support. And as the years changed frontend/headlight styles, you have to get the correct year so all that fits also. Finding a diesel core support can be a problem sometimes.
david85
^^This
u2slow
bilge rat
Coastal BC
Most IDIs use a rad support with a big dip in the middle between the frame rails. Fits a very large radiator; roughly square in shape. Some of the stripper models (like my buddy's '90, non-AC, 7.3/5spd truck) used a short/wide rad with the gas style rad support. FWIW, also the D44 front suspension instead of Dana 50.
BRShirk
Greenville SC
Ok that makes sense. My truck has an aftermarket aluminum radiator ANF I thought if it was just the bolt pattern for rad I could drill new ones.
My support is cracked and they braced it with angle steel. Are the repops any good.
Gasser is an 89. Diesel is a 91
Dana 44HD front was standard on the f250 single cab trucks, no matter what engine they had.
