Let's talk about pyro's and temps...
Yes, I am stealing from F350camper's intercooler title.
Here's why...
Today I put together three salvaged components to get a working pyro setup. Yes, I am a cheap SOB when it comes to my own junk.
After reading about goatboy's comments many threads ago, there's no magic to pyro probes. I had a ATS WG crossover that already had a thermocouple bung welded in on the driver's side and thermocouple installed. Knowing there two ranges of thermocouples marketed, I Installed a Bosch(AUS) gauge and wiring harness from a salvaged truck. Believe it or not, the whole darn thing works. The gauge registers pretty quick after startup and moves around resonably. Its not as responsive as I'd like it to be, but it will serve the purpose in the meantime.
Now here's the results....
around 930pm, 50deg temp, and low humidity.
idle on the driveway....150-200deg
pulling 8k GVW from sea level to the Santa Cruz summit 1800ft at 70mph the best I can get the temps to was 600-650deg
pulling 8k GVW at 95+mph at sea level(or thereabouts) 600deg.
pulling 8k GVW at 60-70mph at sea level(or thereabouts) 400deg
Max boost was no more than 6psi running 4psi nominal. Boost readings are taken post IC at the widest base of the intake feed bell.
I intentionally set my boost low due to two factors. One, I previously had no pyro installed on the truck. Two, the truck gets loaned out occasionally and I don't want the loanee's go racing with any challengers they encounter. It's already bad enough I drive like a nut, if they get caught in my truck doing the same theatrics, they're going straight to jail
So.....what kind of readings are you guys getting with your setups? Temp readouts and boost levels(if any) would really help build an informational database for all to see
Here's why...
