zigzkidz
What is this thing? Everytime i shut my truck off a few seconds later it makes a whistle noise, its just irratating.
Thats the vacuum-electrical switch for your low vacuum dash alarm signal... You never want to see that lite up driving down the road with vacuum assisted brakes. A 6500 lbs crewcab does not stop very well without vac assist brakes. This is one very good reason for the hydroboost brakes...
i dont have a low vacum warning in my dash. I just want that whistle to go away, i think when i unplugged it the sound went away but i havent really checked
I recall there being a pressure-differential sensor in the proportioning valve as well....set to make the light come on if the pressure difference between the front and rear brakes isn't what it's supposed to be. Too lazy to pull my shop manual out at the momentLow brake fluid, low vacuum and the parking brake deployed are the only things that should turn on the brake light AFAIK.
and I COULD be mistaken....but I recall it being there...
