What is this part called??? Oil pressure sender port crack.
Macrobb
North Idaho
Ya I'll try and pick some up. When it leaked BIG before I realized it was cracked, it pooled in the area behind the motor that's below the top of the motor and comes out a bit...... Can't think oft he stupid name right now of that spot...
Get back there with a screwdriver and clean out the drain hole. It's just behind the CDR hole/turbo oil drain spot, and is a 3/8 square hole. This will keep oil from pooling there, and let it drain down a channel off the side of the motor over by the starter.
tke395
