Hydro-idi
That amount of blowby is normal in my opinion. Next thing would be to remove valve covers like you stated in video. This noise has got me bamboozled lol.
It smells like Marvel's Mystery Oil! ... I poured 12 ozs in the fuel tank to try to loosen up a theoretical stuck injector, so the smell test won't work... But it is alot of blue smoke...What does your oil smell like?
I'll do that after I check the valve train... If the valve train checks out, then I'll have nothing left to lose...A bad injector will cause excessive blow by and your noise.
Stop where you are at and replace that injector and see what happens.
Nope... I don't have any replacement copper washers or spare injectors either and if I cut any of the olives, I'm screwed again...Are one or more injector lines scalding hot when the engine is running?
Well, the guy at Southeast did say that the smoke is oil burning with some raw fuel mixed in...Hmmm so the suspect injector was replaced and no change. I am still interested as to what type of smoke is comin out of your tailpipe. It kinda looks blue from the videos but still a little hard to tell. I was always better with my sniffer than my eyes with exhaust smoke diags anyway. Does it definitely smell like raw diesel or oil burning? I wish this was smellovision! I watched your videos over and over again and dare I say but the sound sounds stronger when your camera is near the oil pan, but I dont want to jump to conclusions as its only a video and im not actually there crawling under your truck. I would still try hard to rent or borrow a diesel cylinder compression tester next to see if itll tell you if you have a cracked piston, bent or burned exhaust valves or even a piston slap noise and we'll keep helping frpm there as best we can on here!!
