Hydro-idi
Maybe he should check the blowby as well. If it is a cracked piston, there will be plenty of blowby.
I missed that he has an E4DOA, so that doesn't apply to him. Regarding your truck, I don't think the clutch will make much of a difference, although I admit to not knowing for sure (I put in a SMF when I did my trans swap, so this is partially based on what I've seen on other trucks and partially based on theory). But, if the issue is the two pieces of the flywheel moving more than they're supposed to against each other with every power stroke, I can see the clutch not making a huge difference...dunno about bill's truck but i can tell you mine is a DMF but I really dont know its condition or mileage. and pushing in the clutch doesn't change the tone/noise at all
I have the CDR and I think it's the original one. If I had a cracked piston, wouldn't blue smoke come out of the oil filler neck when I take the cap off?Do you have a modified rdt or the original cdr? If you have the original cdr, pop off the air filter bowl and take a look inside to see the amount of blowby you have with the engine idling. A cracked piston will cause massive amounts of blowby. Replacing your cdr right now is the least of your worries in my opinion. I would then pop off valve covers like stated and check things out with it running to possibly isolate problem
