david85
I have been very interested in the idea of having 2 top gears as you have apparently done, one for towing and the other for running empty. My tranny is a ZF5 and the overdrive ratio is .77 Do you think the 3.08 is too tall for this setup? I am running the same tires you are.
About the 3.08 gears....
If you don't need to tow some 10000lbs consistently, then I would go for it. However, you can never go with 4wd because there is no 3.08 or 3.07 ratio for the D50 or D60 front ends. I think the ZF 5 speed has a granny first gear, so getting heavy loads moving even up hill should be fairly easy even with 3.08s. In my case the low stall torque converter does that job for me.
3.08s with an overdrive transmission in these trucks is ideal for speeds of 70 MPH or up. If you don't spend much time there, the upgrade may not work well for you. In 3rd gear at 70 MPH, my truck will pull hard and steady even with a trailer behind me. 4th gear requires a light foot and sometimes picking up speed for hills. You must also keep a close eye on the side mirror to prevent lugging smoke. Once that happens, there is no gain in fuel economy any more.
So far, I'm the only one I know of that is driving a truck like this with 3.08s. I know that 3.55s and a ZF 5 speed have delivered up to 22 MPG in some cases. I'd love to see what a ZF and 3.08s could do. It seems logical enough to me that a truck could have 2 top gears, one for towing and one for cruising empty, but it seems that even now, there are no trucks build this way. Every truck should have the righ gear for the right conditions.
