what do you guy's think of 4:10's
G.W BUFFALO
effort, pa
ok i got a 1988 f-250 wit a na7.3 and a 5spd. it has 3:55's in it but the d60 i am getting for the front has 410"s, so i have to build a rear. either i can put 3:55's in the front rear or put 4:10s in the rear rear. how do you guy's think 4:10's will work, what will this thing top out at. i want to be able to run at least 70-75 without it screaming like a nut's. also i plan on running a 35" tire. thanks
ocnorb
IDIT
Wasatch Front
I would keep the 4.10s with the 5 speed and 35 inch tires.
This gearing calculator lets you look at two gearing options side by side:
http://www.grimmjeeper.com/gears.html
You could put the stock gearing and tire size in to compare.
I want to run 37's on my '57. Using this gearing calculator I figure it will work ok with 4.10's, but 4.56s would put it closer to stock. (I am using a GV overdrive) I will probably use 4.10s because of $$$
Hope that helps.
G.W BUFFALO
effort, pa
so if i read that chart rite i should have a top end of 109mph rite? not tat it will have enough balls to run more than 80ish.. lol
ocnorb
IDIT
Wasatch Front
Yep.
That's why I'm contemplating 4.56s for mine. ;Sweet
I'm just shooting for 2000 rpm at 70 ish...
ocnorb
IDIT
Wasatch Front
Here is 3.55's with 35 inch tires and ZF 5 speed:
(Yes I am bored- waiting for the wife to get ready so we can head out:rolleyes:)
G.W BUFFALO
effort, pa
so realy it would be a slug if i kept the 3:55's. i realy never go on the highway, highway use will be rare for this truck so i'm better off with the 4:10's.. thanks man
GOOSE
Happy IDI'er
Galloway Twp, NJ, USA
I would go with 4:10's. Number one reason is to keep strain off of the drivetrain. The trans, t-case, yokes, axles and such will thank you when the going gets tough. Your 35" tires are going to put you roughly where a 3:55/stock tired truck would be anyway. Good luck;Sweet
lotzagoodstuff
Carmel, IN
I have 4:10s and 35s on my truck, it's n/a and I've gotta tell you it's great for towing. You won't be "cruising at 80 mph": the sweet spot for mileage (and sanity) in my truck is about 62 on the speedometer.
Stick with the 4:10s if you aren't going to do any long commuting, you will love it when you put a trailer/load behind it.
lotzagoodstuff
Carmel, IN
Fuel mileage is all about what speed you drive at. The difference between 65ish and 75ish is probably close to 50% :eek:
tke395
