Well, Glow Plug controller.
Fullsize4life
Now with More Smoke
Mich
So after work today i go out and start my truck, Cycle the plugs, fire the truck and go back into the break room to let it warm up. About 10 min later i got out and get into it and i see the glowplug light is on. So shut the truck down and restart and the light did not turn on. So im either thinking the contoroller took a crap, Its is only 9 months old. , Or the light is bad. Im sure my new Beru glow plugs are now junk. I will check tomorrow. Any ideas? Yes it is a 6.9 contoller.
Thanks.
Diesel JD
Gainesville, FL
Yep that latching relay failed in the ON position and bit you in the butt. I would switch to a momentary toggle and 12V glow plugs from a 5.7 if it were mine, or spend the bucks to convert to a 7.3 style system. You could still use the ZD-1A berus with a momentary toggle but then you have to be very careful about not letting the switch on for more than 8-10 seconds. The 12V plugs would take longer to heat up but it is practically impossible to burn them up plus they will fit your current harness and connectors. I think Micheal Fowler is running them at the moment. I think the plugs you want are AC Delco 7G if you can find them, you can look for a 1979 Olds diesel Delta 88 if you need to search based on a particular car/truck. Be careful getting those old glows out. At least bring the pistons all to TDC when you're working on them so if a tip breaks off you can suck it out through the injector hole and not have to pull the head.
Fullsize4life
Now with More Smoke
Mich
Im hoping they are not too bad. I put berus in about 3 weeks ago. I hope they are not as bad as the autolights i took out.
