geonc
SPIDER BAIT
On my water pump, there is a seal ring["O" ring] in the metal tube with a flange that connects the lower rad hose [inlet] to the pump...I gots a dribble from there
so I drained the coolant, removed the adaptor and found a seal ring...it is intact
so I cleaned it all up with a scotchbrite pad on a die grinder--no cracks visible so I greased the seal ring up and re-assemble....barstige still drips ![Cussing -cuss -cuss](/styles/default/xenforo/smilies/cussing.gif)
So....the question is....anyone have a part# for that seal ring? All I can find is the gasket for the pump to the timing cover![Frustrated :frustrate :frustrate](/styles/default/xenforo/smilies/frustrated.gif)
![Backoff :backoff :backoff](/styles/default/xenforo/smilies/nunu.gif)
