geonc
SPIDER BAIT
On my water pump, there is a seal ring["O" ring] in the metal tube with a flange that connects the lower rad hose [inlet] to the pump...I gots a dribble from there so I drained the coolant, removed the adaptor and found a seal ring...it is intact so I cleaned it all up with a scotchbrite pad on a die grinder--no cracks visible so I greased the seal ring up and re-assemble....barstige still drips
So....the question is....anyone have a part# for that seal ring? All I can find is the gasket for the pump to the timing cover
