gandalf
Senior Member
Nice set....and that # is clear and easy to see...can you explain the two parts for everyone?
Al
Good thought, Al. It may not be entirely clear, just looking at these wrenches, and they didn't come with directions or documentation. Gary gave enough that people could probably figure it out.
The larger, shorter, wrench fits the four bolts on the pulley, so you can hold it from moving. The smaller, longer, wrench fits on the fan nut, so you can loosen it while holding the pulley and shaft steady with the other. Both wrenches are made for a 1/2 inch breaker bar to fit, for more/better torque. As Gary mentioned, the pulley wrench can be arranged so the breaker bar jams up against something solid and is held there by the force applied, so that all your energies and frustrations can be applied to the fan nut.
Since you had to ask this question, I had to get up off my butt and go outside for pictures. I'll put one in here so you can see how they fit. The shorter wrench is a bit harder to see, but it's there by the pulley. I did not put breaker bars on either wrench for the pictures. Gary, sorry about the picture focus, but you can get the idea.
Actually thats a great pic showing how the two differant wrenches fit. Twice now after useing the nut wrench to crank over the engine to line up the fuel screw I have forgot to remove it. Then cranked the engine to start only then hearing I left the wrench in place. Lucky for me it gets thrown out the bottom when it gets around to that location but I hear it clanging off the fan blades too... I'm a lucky guy sometimes... That wrench can really wind up making a big mess of things easily.. I never leave it on the fan nut any longer Making the same mistake is crazy... Once is enough but twice... Nope I feel three times and I give up my tools...
