WANTED GEAR VENDORS OD
PackRat
Buzzard Pilot
Kansas
I've got one, but the transfer case rear housing is damaged. I bought it at an auction with the intention of converting it to a divorced unit, for my Chevy's SM465, and 4.56's.
Actually, I haven't even been able to test it, to see if it is functional.
If you're interested, send me a PM with an offer, and I'll get back to you.
hugeredford
snow drift buster
fancy prairie illinois
I've decided I don't want one because I called a guy at their main office and he was a ***** and to get any adapter you had to turn in the old adapter, OH and $650 to trade and a rebuild on one was like $750 I figure the cost of a used one and an adapter and a rebuild in the future I could buy lots of that sweet no. 2 diesel fuel.
NapaBavarian
Dually driver 6.9
Napa CA
It is a Laycock de Normanvill OD, GV just selles them with the adaptor, one of these days I'll start making adaptors, gotta go to the junk yard and buy an old Volvo transmission with the OD on the back :)
Not as simple as you make it out to be.
there's actually three different modern versions of the Laycock OD unit. The one that can handle the HP and torque of our motors is the type "P" unit. You don't find those behind volvos too often. You will find the "K" or "L" models more often than not.
NapaBavarian
Dually driver 6.9
Napa CA
From what I can tell the cases are the same, so I could mock up parts with the smaller one and use it in a small car, but only the newer (1987? up) volvos had the type P, a little harder to find. I also want to disect different models so I can see what is really inside and how they compare since specs I have found are difficult to use for comparison.
