Valve starting to stick
CDX825
filtration nut
Litchfield,Ohio
I agree that its probably a lifter bleeding down. Your oil choice most likely doesn't have anything to do with it. You just have a bad lifter.
7.3s are also known for valve guide issues because they used tighter seals than the 6.9 did. So instead of using a bit of oil they wore valve guides out faster. Was done for emission reasons from what Ive been told.
Chuff out exhaust indicates ex valve huff out intake ...take off air filter lid....indicates intake valve....
Thats easy check
Thats easy check
That's if the valve isn't seating. If it's not opening, like I'm guessing it is here, it's different. If the exhaust valve doesn't open, then the pressure of the piston rising will go back out of the intake when the intake valve opens. If the intake valve doesn't open, there probably won't be much noise coming out of the exhaust since there's no air getting into the cylinder since the intake valve isn't opening. There probably wouldn't be much extra noise in the exhaust. At least this is the way that I see it.
pastorjeep
Gatesville NC
I had a Jasper 7.3 that stuck a valve at 70thou and bent the push rod and collapsed the lifter. I had to beat the valve out with a mallet. It was doing the same as your for about 500 miles and then seized. The machine shop said the tolerances on all the guides were too tight.
Hydro-idi
Lodi, California
Sounds about right for a jasper rebuild unfortunately.
Joseph Davis
Lompoc, CA
If a valve doesn't open start checking for metal in the oil pan or a loud clacking noise from valve covers. valves can get stuck open and usually big loss in power because cylinder will not fire. The ratting noise you are hearing most likely coming from IP at start up, because the gears can make a lot of noise when not timed right. I know because I ordered a Diesel Timing Meter and timed mine. there is no comparison to a properly timed motor. When I hear a lifter ticking check oil level first, and if needed I added Gunk Valve medic. Mechanical failures make a lot of noise and last for a long time, and hiccups good luck, could be any thing, only time will tell. But your first thought being the Valves do a compression test because that will never lie. Good Luck and I hope for the Best
Macrobb
North Idaho
On the intake side, if the valve isn't "stuck" and just not being pushed down at the right time(collapsed lifter, loose rocker, bent pushrod) you'll get a loud thumping as the engine draws a vacuum hefore the valve finally opens and air rushes in.
Never thought of that. I haven't seen this before and I can't really imagine what that would sound like. Hopefully, I never will.
crash-harris
Breaker! Breaker!
Chillicothe, OH
THIS is what I get most of the time.
Mike_42
Kid Mechanic
Canton, MS
Well since I added the MMO it has done it a few more times, seems like its getting more common. Im thinking about just doing a flush of somesort and changing the oil again, what do you guys reccomend? Each times its done it its on one cylinder and does it like 3 times..
About to pull the valve cover what gasket should I get and where?
Mike_42
Kid Mechanic
Canton, MS
It also makes this droning noise when idling I can hear on driver side and not passenger. Not sure if valve or exhaust leak or what. If it werent for being a DD id pull it and rebuild.
Where do you guys buy your lifters, pushrods, etc?
Mike_42
Kid Mechanic
Canton, MS
Im surprised I have, I baby the hell out of this truck, alwaks kept on maintence, it only has 235k..
pastorjeep
Gatesville NC
It still sounds like a sticking valve to me. I was able to get pushrod and lifter at a Ford dealership about two hours away, just went to my local dealership and had them check the network to see who had the stuff on the shelf.
olsen726
