Drew2010
pushrod length could be an issue if too much was machined...
JM2CW...
There was no machining.
JM2CW...
I bet at the such tight minimum clearances these have , the VR headgaskets are thinner Than what you took off, engine history, ? used, reman, any idea.
Sorry to say it but you have plenty of measurements to be taken before you find out whats going on.
I dont think its the cam, there isnt that much more lift built into it, any sign of the key broken or anything, this is really wierd. shaving the pistons 20 wont hurt
If you wanna pull the cam let me know and I will get another on the way to you and they can check it on this awesome machine to see if it is the problem, if it isnt Ill have good deal on a used torque cam. its prettty close to coming out at this point.
