Essentially. If you are doing switches, I'd do a momentary on the pull coil and a regular on the hold coil. The only problem there is you will have to remember to release it manually since the throttle pedal and the clutch feed back won't be there. If you were to use a relay instead of straight power at the hold coil, you could probably tie the other switches in so that if any of the switches break contact, it would kill the power at the relay and close the flapper. All depends on how fancy you want to get. If I could get ahold of just the flapper part with a bad controller, I would build my own controller but I'm weird that way.
