Diezel_Cowboy
It's not like a real ***!
I had a friend tell me today that the screw behind the triangle shaped cover has to do with timing and not volume of fuel. He believes turning up the pump consists of turning the screw located in the input line of the pump. From what i gather from the pump manual the screw he is talking about does increase fuel pressure. The screw many here are familiar with (the one behind the triangle inspection cover) actually adjusts the stroke of the pump pistons which would also result in an increase of fuel volume. Someone who knows a lot about these pumps please set the record straight. Are both screws increasing fuel? If so is one better to adjust than the other? I have a hard time believing that turning the screw behind the triangle plate is only adjusting internal timing of the pump. I have the service manual for the DB2 fuel pump published april 1984 that my friend let me borrow but i have never heard of anyone adjusting the screw in the inlet port of the pump. Comments or clarification is much appreciated!
I would still like to hear from the rest of the pump gurus on here as well
