Turn signals gave up
FoolhardyIDI
Arizona
On my way to work this morning, they worked fine. On the way home this evening no turn signals. Hazards work, head light switch works. Not sure what to do. As electrical stuff is not my forte. Any help is appreciated.
This is on my 1991 F350 dually.
fyrfghter
Lebanon OR
Probably a turn signal switch or turn signal flasher
Jason1377
Arkansas
Could a bulb be out and effect that or a fuse have blown just a few ideas.
had a "99 cavalier that has this issue with a bulb out n didn't have turn signals and had funky fuses as well, electrical is not my forte either
two things.
1) start simple. replace the turn signal flasher at fuseblock.
2) cycle hazard button on column a couple of time. they tend to "gunk up" from non-use and if you disturb it just right, it wil affect turn signal switch function since their job is to dusrupt the turn signals.
FoolhardyIDI
Arizona
Pulled the flasher and could hear something loose/ rattling around inside so going to order another one.
Macrobb
North Idaho
Just go to the local auto parts store, it's a standard part.
I Personally like the 'electronic' flashers; much louder 'click', and consistant on/off time. Been running them in all my trucks for a few years now, no issues.
gerlbaum
AZ
Just bought one from Jegs for my led turn signals. Bubs in the AZ summer months just don't last, but LEDs will
Wheelsrollin
