Turboing a n/a 7.3idi
tbrumm
Richland Center, WI
Darn, Wes, If I had known you had 3" down pipes too, I would have ordered from you. Do you just weld a stock size (2-1/2"?) flange onto a Diamond Eye PS down pipe?
Thewespaul
Bulverde, Texas
2.5” vband stepped up to 3” I’ve reworked the diamond eye kits to fit in the past but I just order the materials I need to make it for the IDIT trucks specifically, makes it cheaper for everyone
DrCharles
West Plains, MO
I sell a 3” bolt on downpipe for that turbo setup, and have an intake kit as well.
I had a good amount of the stock intakes but I sold the last one I had to Russ a while ago.
That's what the elbow on my turbo looks like (flange that I assume accepts a band clamp). How much is the downpipe? Are you sure that will clear everything without "adjustments"... ('93 ZF-5).
Thewespaul
Bulverde, Texas
It uses a 2.5” vband so it hooks up to the stock outlet with no modification. It doesn’t need any firewall bashing to fit, if your body mounts are worn down some people will bend the seam over to make it easier to install, but that’s pretty rare.
$175 Shipped
tke395
