fireman438
- Joined
- May 26, 2007
- Posts
- 42
- Reaction score
- 0
I have an '83 F-250 with the 6.9L, which I am seriously contemplating slapping a turbo setup on. So, since I'm not the kind to go into something new uninformed , I called the local International dealership to get an opinion about such an undertaking, since I figured they would probably have a fairly realistic answer. The answer I got was " I would not recommend turboing the early 6.9's because they have a weak block around the soft plug holes and putting a turbo that engine could cause the block to crack starting at the edge of the holes." The conversation continued for about 20 min. and sometime during that, he also mentioned that to keep an engine with a turbo cool, a turbo-back exhaust should be installed, since keeping the stock exhaust would create excess back pressure, and hence raise engine temp. He tried to seal the deal by telling me he had installed over a hundred on 6.9l Fords when he worked at International on the West Coast, then reiterated about being very careful about putting a turbo on my truck.
What I have seen on this forum especially are a number of 6.9's with a turbo. Is the advice given by the International guy valid, or can I safely turbo my rig and not worry about the block issue?
Any advice would be appreciated. Thanks
P.S I'm new here and new to the IDI Fords, but not new to diesels.
Thanks again,
Richard
Thanks again,
Richard
