Greenbeast6.9
grease monkey
i would say it sounds like you got a nice running 6.9l there just waiting for a turbo.
It really depends on your purpose with your truck. WG turbos give a slightly better advantage from a standstill and non-WG is a little better when your rpm's are up. It boils down to which you are more comfortable with. I've installed both and driven both extensively and the similiarites are closer than what most thinkso, do either types of turbos, wastegate or pulse type, have an advantage over the other?? I see a lot of wastegate types, carried by various companies (Banks, Gerrett, ATS, Aurora, etc.), but it seems only Hypermax does the pulse turbo. Any ideas? I can't find anything on the web comparing the two types.
I just checked blow-by and it seems to me that there is very little. I took the cap off of the oil filler tube and put my hand over the hole to try and feel any back pressure because the engine fan kicked up too much wind to watch and too much engine noise (obviously!!) to hear. When I DC'd the shutoff solenoid, a small amount of oil vapor comes out, but disappears immediately on startup, almost as though there were a vacuum (not very likely, though).
