Magoo
Blind Brain Surgeon
I have the ATS turbo with waste gate. I noticed black exaust all over the fire wall so took a look around. The down pipe was flopping loose. So I crawled under and was supprised by what I found. The pipe appears to just slide up into the turbo housing. No clamp? There is a braket which is connecting the pipe to the exaust manifold flange. The bracket was mounted between the flange and treaded part of the manifold. So it is basicly loose. It can slide up and down the bolt at will. There are eight rubber brackets holding the the exaust system to the frame. The whole thing seems a bit cheesy to me. How is the down pipe supposed to be mounted? Any pics oput there? Magoo
