Turbo IDI intake air leak?
Macrobb
North Idaho
Considering even a stock turbo requires quite a bit of fuel to make boost(and actually /use/ that boost), yeah... You'll want to add fuel.
Assuming your turbo is bigger than a stock kit turbo, you'll probably be wanting to add, oh, everything you can get out of the IP if you expect to actually make use of it.
edit:
But, seeing as you have a 6.9, you might want to be a little careful, or install headstuds.
pwillis
