JLDickmon
Bo Duke
Harness was burnt on 5 and 7 couldn't see it but after replacing runs much better. Still has a slight miss when hot but not nearly as bad. I think I need to do something w/ the injectors rebuild or replace.
JIM!
And actually, I work in an chain shop for one of the more well known rubber manufacturers. We'll work on most anything up to 1-ton series, including railroad applications. I might be putting a timing belt on a Geo Metro one day, and changing an injector pump on a GM 6.5L the next.
My Bad. It sounded like you worked in a Ford Dealership.
I know Ford techs get upset when guys slam the stealerships online...
I'm having close to the same issue with the boss's dad's truck. It has a rough idle and run condition. I ran a buzz test and cylinder contribution test and both passed. I'm kinda thinking it may have a leaking o-ring in the fuel system. Any ideas would be greatly appreciated as this truck is making me look stupid. It's a 95 PS by the way.
Id lean towards the the IPR valve o-rings myself.
Rough idle when warm is a classic sign of IPR oring (or dirty gummed up valve) failure on these things. Injector o-ring should lead towards a very black fuel filter. Obviously one would pop to cannister lid to check that first.just out of curiosity,
what would make you think to start there without knowing IPR pressure?
