goehill
I have a 1999 F-350 single wheel 4x4 with auto trans. my problem is when I have my triler on(6000lbs.) and go to start off quick from a dead stop or if I try to power brake it to do a burn out, the engine tries to die out, and if I keep my foot in it , it will die. If I'm rolling with the trailer on it's fine. No lack of power any other time. The truck is stock, I've replaced the icp,it was starting to leak, and had the cps replaced under the recall.I've had no other problems, and the truck is not smoking at all.I am ase cert mechanic, but I don't have access to a reader, truck is not throwing any codes. any one have any thoughts?
