92gold
Truck is a 1992 7.3 idi with ats 093 turbo kit. Truck runs great besides its little air intrusion issue through the selector valve on cold starts. Put a new motorcraft thermostat in in November along with Napa anti freeze with SCA already formulated in. Has a champion aluminum radiator. Truck always runs with the temperature gauge right below the N. Recently when going up the grade or under heavy acceleration the temperature gauge will drop down almost all the way to cold, then when I let off the gas a little to go down the guage will come back but up to the o, and will sometimes fluctuate between colder than normal and warmer than normal. After it does this if I look under the hood and squeeze the upper rad hose it is soft and I can pull the radiator cap off and there isn’t hardly any pressure if any. No oil in coolant, no coolant in oil, doesn’t seem to be leaking or loosing any coolant either. I was thinking maybe it’s the cap but I’m skeptical as it only does this when it’s under a load with around 3/4 throttle. Holds pressure for hours with the truck off if it doesn’t do this before I put it away.
