sootman73
Do NOT use a torch on the wheels. Please see the below video on tire pyrolosis. This is why big rigs tires explode when they ride their brakes.
http://www.youtube.com/watch?v=jBUVzgCHHuA
you aren't using a torch on the wheels just the lug nuts. the heat is not gonna be there long enough to even heat up the wheel.
do one lug nut at a time:
1. heat the lug nut up almost red hot
2. throw the impact on there as fast as possible and buzz them off.
3. throw the lug nut in a cooling bucket so you don't accidentally burn your self
(put new lug nuts on so dont worry about warping the old nuts)4. repeat for the remainging lug nuts.
with this procedure you will not heat up the wheel any more than if you applied the brakes with a large load in tow.
