Well you guys have showed me that I haven't seen it all. Even though I stopped thinking that YEARS ago.
I just went with a gps speedo. Had to get mine working for insurance. It’s the best thing ever.Good point.
I guess I've had so many vehicles with a busted speedo or odo that I've stopped caring. Would do an electric or gps retrofit it came to a "must have".
That is not a typo. He means a little computer to control the transmission. If you truck did not come with the E4od you need to either get a factory controller or there is at least one after market one, not sure if there are more. But it needs that to take the inputs from rpms, throttle input and such to shift into the correct gears when you want them.Can I ask why “e4od is a lot harder becuase you’ll need a trans controller”. A trans cooler takes less than an hour to install and a 6.0 cooler almost bolts right in. I would think measuring and getting the drive shafts right would be harder than a trans cooler.
I was thinking it might be his brother...Asmith, it appears that the account formerly known as Idibobs is back. That's what I got from reading the posts from this account.
There's that too!I was thinking it might be his brother...
