Transmission Lockup
lgettler
Any Where USA Presently C
As I have mentioned before my transmission shift in at out of street driving lockup, plus hwy driving and will not go into cruise control. also the antilock brake light comes on. when this light comes on does it have effect on ths shift problem?
Hey Larry! Good to see you posting. Wish I could tell you, but I've avoided the E4OD like the plague, so I'll have to let somebody who knows what they are talking about answer that one.
dakotajeep
Patrolling
TN/ND
The cruise problem and Antilock brake light makes me wonder if you have a vacuum issue. Have you checked the vacuum system?
THad
71cc
DFW, Texas
From multiple posts with these symptoms, I am suspect of the speedo input.On some of these trucks there is a speed sensor on the ring gear of the rear axle.It is used by the transmission, and ABS .The cruise control might also be affected by a bad signal.Typically the sensor needs to be removed, and at least cleaned.It is also possible that it is cracked, but semi-functional.Start searching the forum regarding that sensor.
DeadMan
Astoria, Or.
I know this may sound strange, but when I had this problem it ended up being the turn signal switch... both the ABS and trans are wired through it somehow. :rolleyes:
Any chance this lockup and unlock happens when the turn signala are being used??? Mine did only when I turned left. Eziekle posted it was a burned out tail lite. Sure enough it was. Seems the stop lite filament drops into the turn lite filament. Then when to use the turn signal it opens the torque converter circut just like what happens when you lightly touch the brake peddle. It makes the torque converter unlock and the rpms go up around 200 rpm. Just imagine how this feels going down the road or on the freeway and you apply the blinkers to change lanes. Lock.. unlock.... lock.... unlock... Not fun but a real easy fix....:sly
JU57US
