Transmission Fluid
JRJ04
Sugar Land, TX
hey guys, im pretty sure its about time for me to change my fluid in the tranny again. i've never done it myself before, but was curious as to if it can be done. I know theres a drain plug on the bottom of the pan to drain the fluid, but how do you get it out of the torque converter. on my '01 f150 there was a drain plug on it (but it was hell to get lined up). is there one on the 4R100 tranny i have?
JRJ04
Sugar Land, TX
Is the drain plug on the torque converter easy to get to, or do you have to bump the starter until it lines up with the hole? I had this problem when I changed it on my F 150 and had to end up putting a wrench on the front of the motor and turning the entire thing until it lined up.
trackspeeder
Stone crusher.
North Branford. CT
If you get lucky it will be facing down when you remove the cover.:D If not you can bump the starter or use a wrench.
tonkadoctor
none ya bidnes
Yep, take off the dust cover.
I usually use a large screwdriver to turn the engine over at the flywheel 1 tooth at a time while I am already under there.
trackspeeder
Stone crusher.
North Branford. CT
Tranny fluid I use Royal Purple synthetic. Expensive but good. You can go with Mobil 1 synthetic. A little cheaper.;Sweet For dino oil Walmart is a good place to shop. :D The filter I get from the Ford stealership.
olsen726
