Trans code Help
Ole BlackBetty
Norman, Oklahoma
Got my new code reader in the mail today. Hooked it up like instructions said to test for OD flashing. Got code 67 with KOEO and 62 in continuous memory. Does anyone have have an idea what these codes are?
I have looked at codes in manual, that came with reader, It gives three entries for code 67, two of them are listed as (cars only) and the other says Neutral pressure switch failure. the code 62 is listed as (cars only) as transmission clutch fault.
FORDF250HDXLT
Maine & Oklahoma
http://www.thorssell.net/hbook/2digit.html
62 = E4OD excessive converter clutch slippage
this can be tricky.it "can" mean converter failure,however electrical issues can cause the converter from locking up properly because it is controlled to lock electrically.
67 = Transmission Manual Lever Position (MLP) sensor circuit
this is your issue at hand,and can also set 62 when it fails or is out of adjustment.
focus on this one first.
http://www.transonline.com/transDigest/magazines/1998-10/Shift Pointers/index.html
http://www.supermotors.net/registry/media/81709
http://www.supermotors.net/registry/media/754896
MLPS measure between Gy/R (SigRet) & LB/Y (TR SIgnal).
http://www.supermotors.net/registry/media/769450
http://www.supermotors.net/registry/media/434182
http://www.amazon.com/Motorcraft-SW...=1353255269&sr=8-1&keywords=Motorcraft+SW5978
truckonfire
