Finally able to start putting this think back together! I know its been like 6 months since my last update. Just lots of other stuff got in the way, both family and other projects.
Anyway, got the new pistons installed on the existing rods:
When I went to install the crank in the block, I realized I was missing the lower main bearings. After searching forever, I came to the conclusion the machine shop pulled them out of the caps when they torqued them down to bore the block. So I ordered a new set of STD bearings from rockauto. I went with a set of Sealed Power 5110M.
Installed the NOS OEM block heater:
Cranked installed and end play at the lower end of the specked range, so that's good.
Cam also slipped in nice and tight. As did the pistons:
I put the old pistons bank in the original block (that's the one where the #5 wrist pin scored the cylinder wall badly). Just need to clear off the workspace for layout out the rest of the parts.
Looking at the valve covers side by side, I noticed that the ones off the '92 have some noticeable humps that my '89 covers don't have:
I'm assuming they are still interchangeable, right? As for the intake, I plan to use my original '89 one since the screen is not all messed up on that one.
My Fell-Pro gasket kit came with a cork oil pan gasket. Should I use it, or just go with RTV only (like ultra black)? If I do use the gasket, give it a light coat of RTV on both sides?
Speaking of oil pan, the drain plug didn't have a washer on it. The other engine had a worn out plastic washer. Would you guys recommend going with an aluminum/copper crush washer?
Today hopefully I'll get the oil pan, front and rear covers cleaned up, and get those installed. Both the '89 and '92 oil pumps look to be in good shape. I'm leaning towards using the one out of the '92 since it still had original sized pistons in it. They both feel fine. Ditto on the water pumps, although again, the bearing feel fine in both.
