TPS screws/bolts
LittleLucy27
Seattle(ish), Wa
Hi all
So I ran codes and the TPS came up
I am trying to get it off to clean/replace
The screws are weird
I've tried everything and nothing seems to grab
I've spent hours searching with nothing helpful coming up
Any udeas?
1991 f250 7.3 idi na
gandalf
Senior Member
CA &/or Maine
You've tried everything and nothing seems to grab. Lets hope you haven't buggered them up in the process. Before you try the Torx drive be sure to clean out the bolt head. I recently ruined a Torx drive because it wouldn't go all the way into the bolt.
Macrobb
North Idaho
There's plastic crud in there, to prevent someone messing with it. Get in there with a pick and pick it out, then T25.
May need a sharp chisel and cut off the heads.Then you can easily remove the bolt threads. Mine were replaced with hex head bolts before I purchased my rig back in 94. I recall they are 14x28 thread bolts. The hex is 7/16. Works fine really..
LittleLucy27
Seattle(ish), Wa
Thanks folks!!
I thought it looked like crud in there......thanks! Just wasn't willing to go there without some form of confirmation......
I'm really short
I have a really bad neck
Which causes weakness in the upper body and considerable pain
Therefore I have to go at a task with a plan )
Thanks so much !!!!
Goof off? Maybe? Applied directly to the plastic. ....I know it will eat stuff you don't want it to;)
LittleLucy27
Seattle(ish), Wa
Soooooooo I'm looking for a new tps
Napa has the motorcraft fir $60
O'Reilly has borg warner for $40
Comments? :)
Advice?
Thanks
Gerhard
